Tamraz's stinger hood
I have Tamraz's fiberglass stinger hood going on my camaro as part of the rebuild. I'm wondering if anyone has pictures of this hood installed with the front of the scoop cut out like an old big block corvette? The problem I see is that the hood is molded with the front flat, and I want to open it up, but not sure how it would look. I would think the bottom of the stinger would need to be extended to run under the top so it doesn't look like a big gaping hole. Here's a pic of what it's like now and the part I'm talking about removing.
And here's a BB vette hood that I'm talking about
Thanks,
Derrick
Thanks,
Derrick
Kind of curious to see how this is going to look on a Camaro. A friend of mine put one on his '71 Nove and it looked good. The Camaro has different lines so I will wait to see it installed before passing judgement
it would be cool to try and make that opening work like a factory cowl hood with the giant hood gasket or something like that just my opinion on it though. it will be cooler though to have it open so the motor is getting a bit more fresh air.
