Sub Frame Paint Removal
Old Feb 13, 2012 | 11:04 PM
Chevynutz's Avatar
Default Sub Frame Paint Removal
Looking for suggestions on cleaning up my sub frame and A/ arm's.
Soda blast,media, shell's, wire brush, LOL
Thanks n adv.
Old Feb 14, 2012 | 10:24 PM
1969 SS's Avatar
sandblast might be your cheapest option. With a frame you don't need to spend the extra for any "specialty" blasting techniques, because you don't have to worry about it warping any panels
Old Feb 19, 2012 | 02:48 PM
JenRich69's Avatar
I just did my 69 front end and I sandblasted all those parts. If you don't have a sandblaster, you can purchase one at a local hardware store (got mine at Buchheits Farm & Home) for around $120. Hooks right up to your air compressor (you need to make sure your compressor is big enough to push the required PSI). I then found another local hardware store that sells the sand for around $5 per bag. I went through about 5 bags blasting all the parts. If you put down tarps you can make a sifter and reuse the sand (which I started doing after I went through the first 5 bags, lol).
That's me sandblasting the front end.
Then you primer and paint and you have:
Jennifer
Old Feb 19, 2012 | 08:07 PM
ToddB's Avatar
I sandblasted mine too. I didnt reclaim the sand and went through 20 bags in total.
vetteback
70-81 V8 Tech
Sep 7, 2013 10:19 PM
c_anderson180
67-69 V8 Tech
11
Feb 12, 2013 04:43 AM
kudnu89
Jan 25, 2011 10:16 PM
67 455 Bird ragtop
Jan 19, 2011 07:57 AM
hugo_a2003
Sep 1, 2006 06:43 PM
