starter size
Old Jun 12, 2012 | 06:23 PM
mikes68's Avatar
Default starter size
well went to auto zone said i need a starter for a 68 camaro with a 396 4 speed thought this would be easy lol got home went to put it in so much for easy it was to small long story short i have a 10 1/2 bellhousing not 11 like bb camaros came with i guess so it didnt fit any body got any thoughts ,thanks
Old Jun 13, 2012 | 07:04 AM
jno's Avatar
jno
Not really sure, maybe bring it back and compare with some others? Mini starter?
Old Jun 13, 2012 | 07:48 AM
fastb's Avatar
I would just get on ebay and buy a mini starter. I did this the other day, got it in and installed it with no issues. Screw autozone, those people have no clue.
Old Jun 13, 2012 | 10:33 AM
dynarider33's Avatar
You have the 153 tooth SB flywheel. The BB flywheel has 168 teeth on it. The SB is 12.75 inches and the BB is 14 inches.
Old Jun 13, 2012 | 11:26 AM
bruce69camaro's Avatar
Also make sure the bolt holes in the starter housing will match up to your block.
Some starters don't have the dual pattern and some blocks don't have the dual bolt holes tapped into the block, so make sure you check that as well.
Old Jun 13, 2012 | 01:26 PM
StoveBolts's Avatar
There is a reason Autozone had a lifetime warranty... and it's not called quality
Last year Autozone squeezed it's supplier even deeper, and that saving is passed onto the customer in the form of "warranty".
Old Jun 13, 2012 | 09:12 PM
mikes68's Avatar
thanks guys
Old Jun 21, 2012 | 03:50 PM
astontibs's Avatar
I have a starter nose for the 153 tooth flywheel. I could send it over to you if you pay shipping. FWIW, it is probably easier to just get the right one at Autozone. PM me if you want the nose.
Old Jun 21, 2012 | 04:43 PM
mikes68's Avatar
thanks for the offer i called the guy that did the machine work on my 66 took him 2min to get me the auto zone part number how i dont know but its in thanks anyway hoping to have it running by the end of july
Bjm3.8
Sep 22, 2011 08:26 PM
microkid
Dec 20, 2010 08:59 PM
TwistedEdge
Feb 12, 2010 05:47 PM
chrshadil
Aug 26, 2007 07:01 AM
