Spark plug wire recommendations
Old Nov 1, 2018 | 09:38 AM
SuperSport_Shawn's Avatar
Default Spark plug wire recommendations
I just need a simple spark plug wire recommendation. I currently have MSD wires and they are horrible , I’m getting a misfire now so I figured I would just toss them. I’ve heard to use the original cables and plugs but I can’t find original cables.. I have found the A/C Delco plugs , but not cables .. any help would be appreciated..
stock 350
edelbrock intake
summit carb 600cfm
Old Nov 1, 2018 | 12:20 PM
peterpar's Avatar
Amazon and Summit Racing both carry AC Delco wires. Here's a link to Summits page. https://www.summitracing.com/search/...2%2B4294951388
Old Nov 1, 2018 | 01:00 PM
flat tire's Avatar
taylor wires
nuff said
Old Nov 1, 2018 | 02:41 PM
Zspoiler's Avatar
Check at most any GM dealership .Auto Zone and other parts stores may have them.There are also Accell .Taylor and other brands as well.
Old Nov 4, 2018 | 08:20 PM
yea the dealer wants about 100$ for the wires , as expected from a stealership , is I managed to get the part numbers and order them through eBay .. for some reason none of the auto parts in my area carried AcDelco wires .. they had the plugs but not wires ..
Old Nov 5, 2018 | 04:22 PM
Zspoiler's Avatar
At least you found them. I would keep looking for other sources for future reference.
Old Nov 5, 2018 | 05:00 PM
Al Loyrat's Avatar
I use Taylor wires on my BBC. Did you know back in the day the factory would loom the V8 Chevys with the #5 wire and #7 wire spaced as far apart as possible? To prevent any chance of a crossfire (Next to each other in the firing order).
Old Nov 5, 2018 | 10:07 PM
Zspoiler's Avatar
It depends on your wire looms.and how you route your wires.That is why I like to custom fit mine,
Volcente
Jan 28, 2012 04:13 PM
buck658
Aug 31, 2011 09:58 PM
domo556
Oct 13, 2008 06:34 PM
Saint_Ali
Jun 22, 2006 08:37 PM
