Roof Repair
Old May 29, 2012 | 08:36 PM
Red 69's Avatar
Default Roof Repair
Hi All
The roof on my 69 Camaro is bubbled real bad under the vinyl, is there a patch panel made that will replace the top and all the way around the rear window?
Thanks
Old May 29, 2012 | 08:43 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
i dont think there is. the roof skin ends at the top of the rear window, than the quaters go way up the c piller and then there is the filler panel under the window
Old May 29, 2012 | 08:48 PM
You may only have a minor case of surface rust. Rust builds crust, but it looks worse under the vinyl.
I'd wait to make a decision till you remove the vinyl top to see what the metal looks like. You might not need a transplant.
Old May 29, 2012 | 08:53 PM
Red 69's Avatar
The worst part is around the rear window, I found a guy parting out a 69 Firebird it never had a vinyl roof put on it and the metal around the window looks good. Will that area be the same as my Camaro?
Old May 29, 2012 | 09:08 PM
Yes, 67-69 Camaro/Firebird, same roof. If you're having rust bubbling by the rear window too, then you could have more serious rust.
This is a rust-prone area, even without having a moisture trapping vinyl top.
lightningcruiser
Apr 20, 2013 08:58 PM
Chaotic94
Jan 6, 2013 09:41 PM
750chop
Oct 28, 2009 09:42 PM
ScarletFire
May 7, 2008 02:44 PM
69camaro400
Jan 10, 2007 12:38 AM
