Remove 327 Heads
Old Sep 14, 2009 | 11:03 AM
camaropal's Avatar
Default Remove 327 Heads
I have a '67 327 motor which broke the #8 cylinder exhaust spring. The intake, header, and head bolts have been removed but the heads are not separating from the engine. Any thoughts on how to remove them? Am I missing any hiden bolts? (removed 17 bolts per head).
Old Sep 14, 2009 | 11:16 AM
lt4weeda's Avatar
as far as i know is that you have 17 bolts holding the head on. only thing me and my brother can think of is the alignment dowel pins. they could just be stuck together from being together for so many years.
Old Sep 14, 2009 | 11:34 AM
No hidden bolts, as long as you got all of them off. It's just stuck in place. Try a putty knife between the head and block and pry up. If that doesn't give, use a thin screwdriver. You don't want to go gouging way in between the head and block and hurt the sealing surfaces. Just pop it up as close to the outer edge as possible.
Old Sep 14, 2009 | 10:05 PM
Y2K's Avatar
Y2K
Sometimes they stick pretty good because of the gasket,a little tap with a big hammer and a block of wood might do it if the puttyknife doesn't get it.
That said why are you pulling the head just to change a valve spring? bent valve too?
sgtdupree
Jan 8, 2011 08:34 AM
car5car
Mar 8, 2008 11:39 AM
camaroquest
May 25, 2007 10:45 AM
suzukikid15
Oct 23, 2006 07:43 PM
