Question on restoring Stock Upper Control Arms
Old Jun 23, 2022 | 09:26 PM
breeze's Avatar
Default Question on restoring Stock Upper Control Arms
I'm in the process of pressing the bushings but had a question on the shaft. Is there a certain way these are supposed to be installed? I noticed a slight discrepancy in size as you can see from the pics and I'm just trying to make sure I don't botch the install. I'm trying to return this press tool and it's quite the drive so I don't want to head back if I mess this up. Does it even matter? The car is at my sister's and I'm using tubular arms so I have nothing to compare them to.
Old Jun 24, 2022 | 09:10 AM
Turbo86's Avatar
Does not matter. The manufacturing of most parts were not made to perfection.
Old Jun 24, 2022 | 12:42 PM
breeze's Avatar
awesome! thank you!
Old Jun 24, 2022 | 04:38 PM
Eric Sabatier's Avatar
I would say what is important is the distance from the tip to the mounting hole on the shaft. I marked mine for L/R, front/ rear and top/bottom but did not paid attention to the way it was made. They are not reinstalled yet and will have a look.
Scott Johnson
Dec 11, 2012 07:28 AM
gagger84
Jul 1, 2011 09:36 AM
Dark Syde
Mar 5, 2011 07:27 AM
vambercidw
Apr 4, 2009 03:24 PM
blg898
Aug 8, 2008 06:02 AM
