Power Steering conversion
Old Mar 1, 2019 | 04:59 PM
gmshadow's Avatar
Default Power Steering conversion
Hi, I am doing the IROC power steering conversion to my 67 Camaro that currently has manual steering. About have all the parts, but the pressure valve in the pump is a problem. The donor car did not have the pump in it anymore to get the valve out of it. The question is where can I get the 1400PSI valve for the IROC steering box that will fit in a 1967 Power steering pump? Source, Part number?
Thank You
Charles
Old Mar 5, 2019 | 05:47 AM
flat tire's Avatar
Thank You
Charles
google this
See 1400 PSI valve for the IROC steering box
Old Mar 13, 2019 | 04:57 PM
MOmilkman's Avatar
I did the power steering upgrade last winter and I used a box off a 96 Jeep Grand Cherokee. While I was at the Junkyard I was told to pull the pressure valve from the pump so I did. When I ordered a new pump (I was going from manual to power so I had to order everything) it came with a high pressure valve, so i didn't use the one I pulled from the junkyard. I don't know if the one that came from the JGC is 1400 psi but I was told it would work.
If you want it, pay for the shipping and its yours
Old Mar 13, 2019 | 05:52 PM
gmshadow's Avatar
Hi, thank you for the offer, but found one at LeePowerSteering. So now down to the pitman arm and the idler arm,. Pozzi says need a different idler arm for power steering, but the Assy Manual doesn't show a different one , Shows same one for man or power. Does look like power steering pitman arm is shorter for the 67 , so wondering what difference it makes between long and short arm?
Old Mar 15, 2019 | 08:56 AM
MOmilkman's Avatar
idler arm? I never changed mine on my 69. I’ve never heard of anyone doing that.
They probably meant to say pitman.
I’d ask them for a part number for the new idler arm. See what they say.
But there is definitely a difference between the manual and power pitman
Savidio
Dec 7, 2019 06:49 PM
hauler
Sep 5, 2017 08:28 PM
shane1617
May 22, 2011 08:35 PM
bgill99
May 4, 2009 11:53 PM
ChevyBoy16
Feb 7, 2007 02:41 PM
