ZZ454 oil pressure
Old Mar 13, 2019 | 08:59 PM
paulkb's Avatar
Default ZZ454 oil pressure
What is an acceptable oil pressure at idle for a ZZ454? The manual, and Summit say that 5 PSI at idle is OK. That seems real low to me even if it picks up with RPMs.
Old Mar 14, 2019 | 07:56 AM
Rule of thumb is 10 PSI per 1000 RPMs. Also you want to test your oil pressure with a good handheld gage. You can verify the hand held gage with regulated shop air. Dash gages tend to not be the best unless it’s a high quality one with oil running to it. I never trust the ones that use a sending unit. Either way I would verify the reading. Regardless of the above rule I would be worried about verified 5 psi at idle for a performance engine especially if it was a new or it loss oil pressure in a short time period.
Old Mar 17, 2019 | 05:35 PM
Coach62's Avatar
What weight / type of oil are you running?
firstcamaro94
Oct 21, 2013 10:57 AM
bbjk08
Apr 4, 2012 12:43 AM
nnewquist
Feb 7, 2010 12:01 AM
Saint_Ali
Nov 3, 2006 02:52 PM
blcp86
Oct 23, 2006 09:53 PM
