Power steering feels like almost none
Old Sep 1, 2017 | 04:43 PM
hauler's Avatar
Default Power steering feels like almost none
I'm looking for a 97-02 Camaro and the 2002 z28 that I just drove has very heavy steering. The used car dealer says they're all like that. Are they, or is there a common seal failure that causes the difficult steering?
Do 1993 to 2002 all share the same steering set up? If so I can find another Camaro to try out.
Old Sep 1, 2017 | 08:04 PM
No, failed seals are not common. The later Z28's have tighter racks then the earlier base models. To compare feel you want to drive a 98-2002.
Old Sep 1, 2017 | 09:19 PM
the power steering pump relief valve can fail. the pump housing is part of the valve and if it gets worn it will make steering tough. it could have a manual rack conversion on it.
Old Sep 3, 2017 | 05:28 PM
hauler's Avatar
Default that helped
So if it's not a pump/valve problem, I can always swap in an earlier rack.
that's great, its fixable. I just bought the car, a 2002 36th Anniversary Z28.
Old Sep 3, 2017 | 11:56 PM
is it whining most of the time.
Old Sep 5, 2017 | 02:48 PM
It is not that simple. The links from the column to the rack are different. I am sure you can find someone to swap everything you need. To people that like performance handling car the 98-02 Z rack is considered an upgrade. I have seen far more posts of people complaining about the sloppy feel of the older racks. Again assuming its work right you are the first person I have heard that does not like the the tighter Z rack. I have owned both and going back to the looser rack would be tuff.
Maybe give it some time?
Old Sep 5, 2017 | 08:28 PM
this is what i was talking about. https://www.detroitaxle.com/shop/ste...24189.95%20USD although you would not have a power steering pump if this was in it
89Camaro383
82-92 V8 Tech
Dec 3, 2011 10:21 PM
drummabrotha
Nov 22, 2011 07:26 PM
95Z28_C.C.
Aug 19, 2009 08:51 PM
1986chevyc10man
82-92 V8 Tech
Feb 18, 2008 06:35 PM
cruz7o3
Nov 24, 2007 09:09 AM
