Paint Sprayer
Old Aug 6, 2019 | 04:54 PM
Jacouncil3's Avatar
Default Paint Sprayer
I have a question on painting and sprayers. Im looking to paint my trailer and dont hve a gun, will be my first time spraying. Will and electric sprayer work and if so what brand and type. I have a craftsmans compressor 150lbs max. but not sure its will be enough pressure to stay constant. Thanks in advance
Old Aug 6, 2019 | 05:00 PM
flat tire's Avatar
electric sprayer will work fine. your compressor will also be fine for a spray gun.
I have actually painted cars with my wagoner electric sprayer
Old Aug 6, 2019 | 05:30 PM
MKCoconuts's Avatar
You gotta be careful with some electric sprayers though, sometimes the tip is the wrong size and it'll either clog or you'll get a really wide spray pattern. Nice thing about them is you don't have to worry about water getting into your paint job. Even HVHP spray guns only require 50-60psi and HVLP usually only require 8-10psi so you're good on the compressor. Also depends on what you plan to paint it with. Single stage? Base coat/clear coat? Lacquer, enamel, urethane?
Old Aug 6, 2019 | 06:47 PM
There are a lot of factors, What type of paint? What quality are you expecting? How large is the trailer? are we talking enclosed trailer, car trailer of landscaping type trailer.
Old Aug 6, 2019 | 09:49 PM
Jacouncil3's Avatar
That would be my next question, i know prepping is everything and i do want it to look nice. Its an enclosed trailer. What would be the easiest paint plus cleanup? This will be a home paint project in garage.
jjz28
Mar 23, 2014 08:45 PM
thebandit110
Feb 22, 2012 06:57 PM
Cody0103
Jan 4, 2011 11:29 AM
78 LT modified
Nov 18, 2008 08:40 AM
camarohelp
Aug 11, 2006 05:46 PM
