New 68 camaro Project..
Old May 14, 2010 | 04:02 PM
Speedjester's Avatar
Default New 68 camaro Project..
I just took delivery of the 68 camaro I purchased..
Here are some pics.. Can someone tell me if the hole in the Transmission tunnel is factory or did some butcher cut it up... I don't believe it was a factory four speed.. Looks like someone cut a hole and drilled some holes for what I don't know... Also take a look at the rear view mirror.. It doesn't look correct...
All in all was how described.. Car looks like it has all its original panels..Need quarter skins on both sides and drivers side floor pan...
Car has 350.. some what of cam a 2 speed powerglide and a ford 9"..
Front disk brake conversion has been done already with drop spindles..
http://s1011.photobucket.com/albums/...jester/camaro/
Take a look and tell me what you think
Old May 14, 2010 | 04:44 PM
Welcome to the Camaro world. Open a www.photobucket.com account. Host your pictures there, then copy and paste the "IMG" code here.
Old May 14, 2010 | 05:54 PM
Thanks 69 camaro... Thanks for letting me join..
Take a look at the pics...
Old May 14, 2010 | 10:38 PM
burnt68's Avatar
December 2010 ROTM
looks like a descent project, probably gonna need outer wheel wells as well as skins?
mirror mount looks original.
if it was originally a 4 speed there would be a square plate around the perimiter of the hole on the bottum side of the trans tunnel.
you can post your pics with the bottum link under each pic like this
Old May 16, 2010 | 07:20 PM
orocker's Avatar
December 2011 ROTM
Santas Little Helper
Welcome to the forum! Nice project....goodluck with it all.
ATM
Aug 30, 2013 08:19 PM
m53ako
Aug 10, 2009 10:59 AM
osduck5
Jun 30, 2009 01:00 PM
dixie
Nov 12, 2006 07:03 PM
