neutral safety switch
Old Sep 7, 2015 | 12:37 PM
southw2's Avatar
Default neutral safety switch
Can someone tell me where the neutral safety switch is located on a 68 camaro v8 automatic. the car is now a stick shift car and i am having trouble with the ignition, not engaging the selinoide .
Thanks
Old Sep 8, 2015 | 05:26 AM
Everett#2390's Avatar
If console equipped, switch is on the shifter.
If column shifted, switch is on top of column at firewall inside.
Find harness connected to switch and jumper the two purple wires together.
Neutral safety switch also has an added function of a back-up light switch.
Reverse switch mounting for a manual trans would be on the trans reverse lever.
Several aftermarket houses, Classic Camaro, NPD, Heartbeat City, sell repo kits for hooking up back-up lights
Old Oct 2, 2015 | 04:28 PM
Inwadvall's Avatar
Default Окна
????? ? ??? Разрабатывались методики снижения себестоимости товаров для снижения рыночной стоимости продукции, что в свою очередь интересовало не только компанию, но и, конечно, Заказчика. ...
Wizard978
70-81 V8 Tech
Sep 29, 2009 07:04 PM
1Bad87gn
Aug 25, 2009 12:14 PM
dustinb
Oct 9, 2007 09:21 PM
Tony67RS
Sep 19, 2007 11:36 AM
Scrufdog
Aug 21, 2006 11:08 AM
