ne headlights
Old Jun 9, 2024 | 07:09 PM
marine's Avatar
Default ne headlights
power to light switch power coming in to dimmer switch power going out of dimmer switch. no power to headlights. I have interior lights, back lights, turn signal lights, and fog lights but no head lights. replaced dimmer switch and light switch. I don't understand. been at it all day. test lighted head lights and have no power going to head lights. 1969 Camaro.
Old Jun 10, 2024 | 07:14 AM
manicmechanic007's Avatar
Your new switch is defective?
That power should come into the switch, you pull the ****, and the power goes out
If that is happening, check the grounds and the dimmer switch
That power should come into the switch on the red wire and go out on the light blue wire to the dimmer switch
Have fun
Old Jun 10, 2024 | 12:07 PM
SoCal67's Avatar
replace headlight switch. Given the full 12v power goes through it for headlights. several including me, installed the headlight relay harness which takes that full 12v load off the switch. Plug and play install. No cutting any stock wires. About $40. I bought mine from Speedway
Headlights, and all other lights, will be considerably brighter...but the stock headlight switch needs to be good.
2 relays mount near battery on core support and draw power from the AUX battery post on PS fender. Stock headlight pug goes into new harness and that plugs into headlight. Harness runs along (under) core support to DS and plugs direct into headlight. You just leave the stock headlight plug on DS unplugged
Phoenix
Nov 24, 2021 08:02 AM
dgriffi2
Jun 28, 2019 01:32 PM
Jward6222
Apr 26, 2018 10:02 AM
maybe next time
Feb 10, 2012 09:19 AM
9camaro1
Feb 12, 2009 07:31 PM
