Motor/Frame Mount Questions
Old Apr 14, 2013 | 11:41 PM
KSCAMARO's Avatar
Default Motor/Frame Mount Questions
HELP! I am installing a 383 with a 350 short shaft transmission in my 67 Camaro, and I need to know what motor mounts and frame mounts I need for proper engine height and transmission mount alignment. I am converting to power steering, and adding vintage air, will I need long water pump or short for proper brackets. This is my first Camaro project, and I appreciate all the help I can get,
Thanks!
Old Apr 17, 2013 | 05:13 AM
bruce69camaro's Avatar
Seeing that the 383 is basically a 350 block, I'd go with motor mounts from a 350. If your car was already a V-8 then your frame mounts would be ok but if not, you can get frame mounts. They are just a bolt in part.
As for the short vs long, if your keeping correct to the year of your car, it would use the short style, but a lot of people will convert over to the long pump.
Zazoos
Apr 7, 2024 09:04 AM
vetteback
70-81 V8 Tech
Sep 7, 2013 10:19 PM
kill3rcrack3r
82-92 V6 Tech
Jun 24, 2011 08:09 AM
Mitch Upton
67-69 V8 Tech
Oct 16, 2010 02:32 PM
brownstone101
Nov 30, 2009 11:52 AM
