Sub Frame Body Mount Bushing?
72 Camaro Sub Frame Body Mount bushing location.
I do not have the old ones for comparison and I'm trying to figure out the placement of the new ones.
I have attached 2 images and labeled the bushings A,B,& C.
A&C are both 2 1/2 inches in diameter, but C is taller.
B is 2 inches in diameter and is about 1/8 inch shorter than C and 1/8 inch taller than A.
Need to correlate A,B,&C with the following mounting locations:
1. Mount under seats
2. Mount at firewall
3. Radiator Support Mount
https://www.dropbox.com/s/4vwcb11xzat7j1a/CBushing.jpg
https://www.dropbox.com/s/725mkdpwf3ulbrg/CBushing1.jpg
Thanks for the help.
This is the info I used from a post way back when I did mine. Worked fine for me:
"Got my rubber bushings from Year One, and the kit came with instructions. The three different size bushings were referred to as "large bushings" (firewall area), "small bushings" (rear mounts), and "thin bushings" (rad support). Also there were 4 large "donuts" and 2 "small donuts" which mount opposite the bushings on the frame side. All the other hardware was depicted too. Unfortunately I discarded the instruction sheet, otherwise I would be able to help you out more."
thank you, i just asked basically the same question you answered here. I was pretty sure but wanted confirmation.
