Looking for info
Old Jan 22, 2015 | 12:17 AM
Grizmo's Avatar
Default Looking for info
Looking to replace ignition. In my 68 Camaro 327 any suggestions
Old Jan 22, 2015 | 12:35 AM
If you still have points & condenser, then drop in a regular GM type HEI distributor. A relatively stock engine doesn't need anything exotic. I helped my brother put an HEI in his 68 (327), and the performance difference was night and day. What was mostly noticeable was the engine starting with a tap of the key where before it had to crank over a couple of times before firing up.
Old Jan 22, 2015 | 10:24 AM
Icecobra's Avatar
I did the ready to run MSD system with MSD6 control box. The cap is much smaller than the HEI unit but it also costs more money. I am however completely satisfied with fit and function...
Old Jan 23, 2015 | 06:43 PM
Grizmo's Avatar
Ok went with MSD ready to run
With MSD Blaster2 coil.
Thanks
RodneysPhoto
Mar 28, 2011 01:44 PM
camarogurl843
82-92 V6 Tech
Nov 4, 2010 02:44 PM
Skidoo03
Oct 18, 2010 06:39 PM
Homestar1217
Jun 27, 2009 08:37 PM
vinnyboombots
Apr 4, 2009 03:14 AM
