leaf spring bracket bolt removal
Old Dec 25, 2025 | 12:43 PM
fredrussell2@comcast.net's Avatar
Default leaf spring bracket bolt removal
68 camaro trying to remove the leaf springs. the bolts that hold the forward mounting bracket are all spinning. Any suggestions on how to remove them?
Old Dec 26, 2025 | 04:42 AM
manicmechanic007's Avatar
I had to cut into the rear subframe of my matching numbers 69 Z-28, when I replaced my rear springs for the same problem
Absolute tragedy, I felt like a butcher when done
It's things like that, that justify selling a nice one
I had to tale an air hemmer with a chisel bit to mine and open 'er up
Tragic
Old Dec 26, 2025 | 09:34 AM
SoCal67's Avatar
your cage nut is spinning. Few methods to remedy, all involve cutting
Old Dec 26, 2025 | 10:24 AM
Got them off yesterday. used a cut off wheel on 4 of them and drill off the heads of the other 2. Thanks for the responses
Old Dec 27, 2025 | 08:07 AM
Good job, the less butchering the better, sounds like you did none
cks
Jan 5, 2025 11:35 AM
joetunick
Apr 13, 2014 05:06 PM
mikes68
Sep 11, 2013 05:50 AM
cadmanof50s
Aug 20, 2010 09:56 AM
WVSPEED
70-81 V8 Tech
Mar 6, 2008 07:02 PM
