Key and Cylinder Question
Old Oct 14, 2012 | 06:02 PM
Roger3's Avatar
Default Key and Cylinder Question
My ignition key barely works. It catches and I have to wiggle it and back and forth to get it to the on position or backwards to the accessory position.
I only have one key.
Not sure if the key is the problem or the cylinder. How can I tell, or how do I fix it.
Is there a number or something on the cylinder that I can use to have anew key made?
Thanks
Roger
Old Oct 15, 2012 | 08:43 PM
xtb-21's Avatar
Chances are,if your key is worn than the cylinder is aswell.Your best resolve is to order a new ignition switch that will come with keys and they are not expensive.
There are a few different suppliers.
Old Oct 15, 2012 | 10:05 PM
Sudstoy's Avatar
These are very inexpensive and are easy to replace, i did it in my 70 after my key got stuck in the crank position.
Old Oct 15, 2012 | 10:16 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
the switch is seperate from actual key cylinder so maybe the switch is still good. I just replaced my switch and the key cylinder is different you can buy a new cylinder with a new key.
Camaro Ignition Switch | 1967-1981 | NPD
Old Oct 16, 2012 | 10:10 AM
You didn't say what year your car is. The ignition switch & tumbler is in the dash on 67-68 models. 69 has the lock tumbler in the column with the switch down low operated by a rod. Both systems work in very different ways.
Roger3
Oct 21, 2012 09:44 PM
hgufrin
Jun 12, 2011 08:40 AM
kyphur
May 5, 2009 08:42 AM
kyphur
May 1, 2008 11:04 AM
derb84z
Jan 17, 2008 08:35 AM
