Intake? will it fit under my cowl hood?
Old 04-06-2010, 02:55 PM
Originally Posted by Flash Mobster
Anybody know of a good replacement intake that will not require any modifications? I have a pace car with a 350.
With a small block just about any intake that's dual plane will work. You didn't mention the specifics of your engine, so hard to say what will work on it. If it's pretty much stock 350 I'd go with an Edelbrock Performer. If it's built then you can go with something bigger, or something with an open plenum. The dual plane plenum will give you better bottom end and power up to around 5500 though.
Old 04-07-2010, 08:31 AM
MS69 YENKO/4-SPEED's Avatar
FYI -I did install the intake and the hood had pleny of clearance. about an inch to spare
Old 04-07-2010, 10:09 AM
Thought your engine went south on you? Did you install it on the bad engine or did you get a new one in already, or did you get it on and then the engine went bad?
Old 04-08-2010, 11:35 AM
Flash Mobster's Avatar
My engine is fine. It's about a year old. It works great. Maybe it was someone else.
Old 04-08-2010, 11:40 AM
Heh, heh, the engine going south was in reference to the original poster. You're confused because you hijacked this thread. You might want to try starting your own thread to get some responses.
Old 04-08-2010, 04:44 PM
Oh thank goodness!
tespjs12
12-17-2012 02:14 PM
mikemaccham
10-24-2008 06:38 AM
Camaro_Kid
08-20-2007 11:05 AM
Mr. Zero
02-22-2007 11:14 PM
larson99ss
LS Series Tech
10-02-2006 10:40 PM
Quick Reply: Intake? will it fit under my cowl hood?
