Intake and Carb Upgrade
#41
You know that is a great question. New inside carpet is on the list, pulling the radiator and getting a little leak fixed, there is a Z-28 at the junk yard I want to pull the steering gearbox from. I really need to work on the suspension some more. It feels very loose and sloppy, so that may be the next bigger thing. There was a secondary going on the same time as this, I replaced the leaky heater core and the soaked firewall pad too.
Oh yeah, I still need to clean up the exhaust hanging, the mufflers are not nice and even like I want them. But I will take it to the auto craft shop on post so I can use a lift.
I aksed Summit what jets I should use here at 6000' and am waiting on the answer.
Thanks for all the help, suggestions are always welcomed.
#46
looks real nice!! good work bud!!!
I havent had a chance to touch the camaro yet i had to replace the flexplate,starter,carpet,package trey and remove bench seat and install buckets in my 71 chevelle!!! what a pain in the **** that was!!!
but turned out nice!!
ok back to edogs camaro pull them valve covers and clean and repaint them!!!
#48
what do you mean by to big??
they make different sized grommets for different sized breathers or you can get the push on style with built in grommet.
