How to know which was the original engine size?
Old Nov 22, 2021 | 08:24 PM
fpereira23's Avatar
Default How to know which was the original engine size?
Hi to everyone,
Is there any way of telling which was the original engine from the vin or Trim tag in a 1969 Camaro?
Vin 3rd digit is 4 so it was originally a V8 but is there any way of knowing which one was it? Trim Tag has a built date of 11A (first week of November).
No H Location code on the trim tag.
Thanks
Fernando
Old Nov 23, 2021 | 05:28 AM
Everett#2390's Avatar
Only way is comparing is by the block stamping, ie, plant, date, and engine code, with the body VIN.
Read up more info at Camaro Research Group
Old Nov 23, 2021 | 06:47 AM
If you could it would make life so much easier. Since all the SS motors were different IF you could tell by the vin what engine came in the car you could prove it was a SS or not. Sadly if you have an a car with a non-numbers matching motor there is no way to know what it was unless you can find a build sheet. Course you can order a build sheet that says anything you want it to say
fury1
Jul 26, 2017 11:36 AM
dizzee03
Sep 22, 2011 01:29 AM
rcknrolfender79
Oct 11, 2009 07:41 PM
rcknrolfender79
Oct 8, 2009 08:05 PM
rcknrolfender79
Oct 8, 2009 08:03 PM
