Hey guys can somebody help with 68 camaro
Does everything work on it? i.e. do all four windows roll up and down smoothly, does the heater, defroster, and vents work?...A/c!? are the wipers working, are the wiper linkages tight? steering tight? leaks? 4 wheel drum brakes or disc/drum? fresh suspension bushings? Is the radio orginal or did someone take a sawsall to the dash to get a walmart special in there?
The problem I face when buying used vehicles is saying "I can fix that". Then all those little things mentioned above add up quick. You don't have to pass on the car because a few things are wrong but, deduct from the price.
elijah503sm
01-13-2012 04:34 AM
Chadb2008918
70-81 V8 Tech
05-17-2009 01:25 PM
SixShooterCamaro
04-28-2009 11:07 PM
