Help with a Holley Avenger rebuild
Old Jul 28, 2018 | 11:21 PM
Default Help with a Holley Avenger rebuild
I am rebuilding my Holley, I have not messed with one for almost 30 years. The Holley 670 Avenger worked great right out of the box. It is getting rebuild due to the accelerator pump failure. My question is on the power valve. The valve I removed from the Avenger had no markings. The Trick kit I bought came with 3 market 2.5,,,6.5 and 10.5. Anyone know where I should start? A way to gage my old un-market power valve.
Thanks in advance.
Old Jul 29, 2018 | 05:08 PM
Al Loyrat's Avatar
On your old power valve there are 3 places the inches of vacuum are printed or stamped. On the small brass spring retainer, on the sheet metal diaphragm retainer, on the hex nut flats. The new one sounds like a 3 stage. Can you post close ups of both? Do you know your idle vacuum for your engine?
Old Jul 29, 2018 | 05:22 PM
Al Loyrat's Avatar
The newer holleys don't blow power valves on a back fire like the old ones (pre 1990 I think). I like to run a p/v that is about 1 1/2 iov lower than the idle vacuum. On my ZL1 I have to run a 4.5 valve because of 6 in. at idle (aggressive cam profile).
Old Jul 30, 2018 | 11:03 AM
I did not check the vacuum before pulling it a part and the last time I checked it was so long ago I am not sure. I set the idle in 07 and have not done anything to it since. I read up on the power valve on Holley's website. I went with the 6.5 for now until I can check the vacuum. The cam is not a stock one but its not radical either.
Old Jul 30, 2018 | 08:01 PM
Al Loyrat's Avatar
6.5 is a good starting point. Most factory and out of the box Holleys came with that valve. When you check the vacuum at idle, use the vacuum gauge to set your idle mixture screws also (set at highest vacuum reading when adjusting mixture screw). I was looking at my can of p/valves last night, all 14 of them!
Old Aug 2, 2018 | 01:34 PM
It looks like the original was 6.5, Under magnification it looks like an E, a 6 then a 5. Its tuff to see. I started the car and she fired right up, Accelerator pump seems to be work fine. I just need some Anti freeze and I can test drive it.
Old power valve
Old Aug 2, 2018 | 06:28 PM
Everett#2390's Avatar
Good deal. Nice work.
Old Aug 6, 2018 | 02:03 PM
The issues returned, It ran good in the garage but under load the hesitation/ flat spot is back. Today when I went out to check things I realized the accelerator pump stopped working again. This time the spring is flexing and the pump arm is not moving. After playing with it I am sure the check valve under the squitter is stuck. I remover the squitter and played with the pin and the acc pump started working again.
Old Aug 6, 2018 | 07:34 PM
So I got the pin out which was way harder then it should be. I could see nothing in the bore even with magnification. I check the diameter of the aluminum pin and found a drill bit a few thousands undersized and used the drill bit with my fingers. I felt something at first. but then the bore was clear and I installed a new pin, even though there appeared to be nothing wrong with the original pin. She runs great. I put about 20 miles on her tonight.
68CamaroSFL
67-69 V8 Tech
Jun 19, 2012 06:16 AM
kyles_81camaro
Apr 13, 2011 03:48 PM
n269nando
Jul 20, 2007 12:22 PM
Eric89RS
Mar 25, 2007 02:28 PM
crcorc
Apr 24, 2006 03:09 PM
