Heater core
Old 08-26-2019, 06:09 PM
flat tire's Avatar
fix your original and move on
Old 08-26-2019, 06:50 PM
17 Again's Avatar
If I had a radiator shop around here that didn't charge an Arm and a Leg and all my Fingers I would.
Old 08-27-2019, 10:13 AM
classic1's Avatar
Former Sponsor
Originally Posted by 17 Again
Ray Thank You for your info. I believe I have seen others with the same problem as mine. Any idea why the 69 core would be in the 68 heater box? Could they have originally come with them? Mine appeared to have been in there for a long time.
Hi 17Again,
After conducting some additional research, I have come to the conclusion that there may have been a mid-year change where some of the 1968 models may have been assembled using the 2" core.
See attached GM parts book entry from October, 1970 that references this change.
Part # 3011432 superseded to the part number referenced in the GM part book.
I feel that this confirms my suspicion that your car is equipped with the 3011432 heater core.
Old 08-27-2019, 10:28 AM
17 Again's Avatar
That is nice information you located, my car was built the 4th week of March. I wondering if they changed the entire heater box with the change in the core size.
Old 08-27-2019, 11:25 AM
classic1's Avatar
Former Sponsor
Hi 17Again,
I looked at the parts book published in November 1968, and the one published early the next year, in February of 1969. (see screenshot)
It appears that there were 4 possibilities for the case: (In my opinion, the part # for your case is listed below in bold text)
It does not indicate that the case changed. Looks like the case remained the same whether you had the 2" or the 2-1/2" core.
3015134 - Case - 1968-69 Camaro (except 396 engine) without AC
*use CI Part # 3013319 for 1968 Early Builds with 2-1/2" core
*use CI Part # 3011432 for 1968 Late Builds with 2" core (supersession #3016842)
*use CI Part # 3011432 for 1969 models
3015141 - Case - 1968-69 Camaro (with 396 engine) without AC
*use CI Part # 3011477 for 1968 models
*use CI Part # 3018864 for 1969 models
3015606 - Case - 1968 Camaro with AC
*use CI Part # 3009917 for 1968 models
3018763 - Case - 1969 Camaro with AC
*use CI Part # 3018489 for 1969 models
Old 08-27-2019, 02:17 PM
17 Again's Avatar
This is good info to hold onto. I know others have had this problem in the past. Hope it is seen by those that need a 68 core to realize the change and which one to order.
I did receive my shipping label to return my core today. My last 68 I had was sold in 1978, I had a 69 Z28 X33 in the early 80's but sold it in 1984. Ive only had the 68 I have since July. Thank you and Classic Industries for the help I needed.
Mike Sharkey
Old 08-27-2019, 06:46 PM
classic1's Avatar
Former Sponsor
Mike Sharkey
You are very welcome, Mark. We are happy to be of assistance to you.
Wishing you best of luck with your build. Please let us know if we can be of any further help.
Old 06-02-2020, 10:00 AM
Warthog639's Avatar
Glad I looked here FINALLY!! Been going crazy trying to figure this out the last couple of months. This all makes sense now. I was going by the catalogue, but nothing was matching up. Going to return everything and order the later heater core and it'll be done!!
Thanks for the info!!
Larry D.
kamaro kid
06-02-2020 08:34 PM
Icecobra
12-09-2014 07:29 AM
95Z28pit
09-18-2007 07:01 PM
alabama1967
07-19-2007 12:46 PM
mike86rs
03-13-2006 11:29 PM
Quick Reply: Heater core
