Header Ground Clearance
Old Jun 27, 2011 | 09:00 AM
StoveBolts's Avatar
Originally Posted by Kamaro
Just make sure you don't have ceramic coated headers, using wraps with the ceramic coating will void the warranty and cause the coating to discolor and flake.
Ohh, I don't have ceramic headers. Wish I did so I didn't have to wrap mine. Pretty sure I went with the cheapest Hooker I could get since I was being sold the idea I had to go custom or nothin at the time. My buddy with the 2nd gen 383 has ceramic headers and I was amazed how his plug wires are right up against his headers and they are fine. I'm running MSD wires and the reason I wrapped my headers is because it started melting my wires....
Maggie,
Great thread! Thanks for sharing!
Old Jun 27, 2011 | 10:13 AM
Raising the engine mounts only complicates collector clearance issues. Since the trans mount stays where it was this brings the front of the engine higher, but the engine sits at an angle. Anything behind the flywheel goes down as the front of the engine goes up, so the farther back your collector, the more it drops as the front of the engine goes up.
It's not a huge amount, but if you've already got issues, it adds to them.
Old Jun 28, 2011 | 03:38 PM
StoveBolts's Avatar
I hear ya. When I got my performance motor mounts, I also got a performance transmission mount. I don't recall exacty what it was cause it was so long ago, but I do remember having to cut part of the transmission support out along the edge. About a half inch if I remember right. Anyway, had to cut it off and then weld it back up so something would fit right... darn, can't remember why I had to do that...
Old Jun 28, 2011 | 08:39 PM
Originally Posted by StoveBolts
1971,
Now I feel better! Thought I was the only one that couldn't remember important car stuff!
Old Jun 29, 2011 | 07:38 AM
StoveBolts's Avatar
ha, isn't that the truth! My mind isn't as quick as it used to be. Too much stuff in there and takes awhile to sift through it all... at least that's what I want to believe so it must be true...
But now it all comes back to me! I have a fancy dancy deep aluminum transmission pan and it wouldn't clear the transmission thingy do-hickey
What in the world this has to do with header clearance I don't know
zambu
Mar 7, 2012 09:18 AM
BLKOUT
Oct 19, 2010 04:14 PM
gray80
Sep 16, 2009 08:35 PM
v8chvyguy
May 20, 2007 11:13 AM
v8chvyguy
May 19, 2007 10:51 PM
