generator light comes on
Old Sep 17, 2011 | 09:59 PM
jeu510's Avatar
Default generator light comes on
hey guys, im new to this forum...just picked up my 68 with 327...nothing special. just a coupe with rs front end conversion. anyways, the generator light comes on while engine is running, but slowly goes off when rpm is rev'd up. just wondering if i need a new alternator. thanks ahead...
Old Sep 17, 2011 | 10:34 PM
stea's Avatar
I would assume so. The alternator is needing more RPM go get the charge up. May be the voltage regulator. Easy way to find out is to run it by an Auto Zone or Oriellys, they will check it out right there.
Old Sep 18, 2011 | 12:34 AM
If your car still has the factory setup, you have an external voltage regulator, mounted on the drivers side of the radiator core support. You can check the alternator output with a volt meter. If it's putting out in the neighborhood of 14 volts, replace the voltage regulator.
Socom
Nov 9, 2013 01:41 PM
hpd218
Aug 24, 2010 12:05 PM
woodysresort
Jun 1, 2009 07:12 AM
evilbeef54
Jul 27, 2008 09:47 PM
