Front clip replacement opinions needed
Old Sep 2, 2007 | 09:44 PM
buckmaster's Avatar
Default Front clip replacement opinions needed
I will be replacing the front clip on my 69 conv. this winter. I have a donor unit that I want to detail and rebuild for the swap. I am not looking to run a road course with this car, but would like to improve the steering/handling/feel of the front end. Any suggestions on ways to make improvements to the front end without going broke?
Thanks
Old Sep 3, 2007 | 12:00 PM
1969 SS's Avatar
Default RE: Front clip replacement opinions needed
what is your pricerange?
Old Sep 4, 2007 | 06:18 AM
Blade's Avatar
June 2007 ROTM
yes def need a price range.
Old Sep 6, 2007 | 04:52 PM
buckmaster's Avatar
Definitely less than 1k
Old Sep 6, 2007 | 08:58 PM
jonnyNITRO's Avatar
Good Luck!
A disc brake conversion costs $1000 alone. You need bushings, tie rods ends, pitman arm, idle arm, torsion bar rubbers and ball joints too.
Old Sep 9, 2007 | 08:56 PM
buckmaster's Avatar
Already have disk brakes so that won't be in the cost. What about rack/pinion steering or control arm options? Anyone have experience with the bushing upgrades and thier effects?
Old Sep 10, 2007 | 10:12 AM
jonnyNITRO's Avatar
I have swapped out the old bushings on my '67 Camaro years ago with the Energy Suspension polyurethane. Very tight after that. Handling was much better. The red bushings squeaked, so I put in the black ones with graphite. No more noise. Great stuff. I put them on my '71 front clip too.
Old Sep 10, 2007 | 11:14 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
You can check www.riskscamaros.com for oem type replacements or www.classicindustries.com for stuff as well.
2ma2
Jan 24, 2013 08:05 PM
bd92rs
Dec 9, 2011 02:29 PM
chevy2race18
Feb 16, 2009 10:31 AM
patman
Jun 27, 2007 04:53 PM
