Fly wheel diameter and number teeth.
Old Dec 24, 2021 | 07:27 PM
Buchananr's Avatar
Default Fly wheel diameter and number teeth.
69 Camaro with a 350 and TH350 trans. Intermittent starter engagement - intermittent clicking, won't engage, wont start.. Are there different size flywheels that will fit a TH350 transmission? What is the correct diameter for the flywheel? Correct number of teeth? Have worked on all the typical issues - good grounds, engine, bdoy, freame, installed new starter, new cables, double checked all wiring, fiddled with shimming, but still have the intermittent clicking-won't egage, won't turn. Sometimes no problerm at all, sometimes it clicks and does not engage after only two or three tries, sometimes more. Would appreciate any advice. Merry CHiristmas
Old Dec 24, 2021 | 11:22 PM
Probably needs shimmed correctly,common issue with Chevy starters.
Old Dec 25, 2021 | 05:56 AM
Everett#2390's Avatar
Check battery voltage at the posts during cranking - should not go below 10.5 volts.
If it does, need a bigger cap battery or a good external charge.
Adam78
Nov 17, 2009 01:07 PM
Goodfella
Mar 16, 2008 07:20 PM
1994z28
Nov 25, 2007 03:49 PM
podsy555
Oct 16, 2007 08:36 PM
MIKESYENKO
Dec 26, 2006 10:05 PM
