Does this need to be covered?
Old Apr 30, 2019 | 11:49 PM
mwightman's Avatar
Default Does this need to be covered?
[Sorry if this is a repost; I made a post on this topic a few days ago and it looks like it has vanished. If it was deleted because I broke a rule, I'd appreciate it if someone would tell me.]
I have a 1969 Camaro 350 SS; I've been working on it for a while and I have the engine about where I want it, so I've moved on to amenities like the ventilation system. I have a question, and I've not been able to find the answer in any of the manuals I have for the car.
When the car is in motion, I can feel air blowing into the passenger compartment by my legs. It isn't coming from the vent on the side near the floor; it's from somewhere else, maybe near the pedals. The airflow is only there when the car is moving, and it gets pretty warm after the car has been running for a while. I don't think there are any rusted openings in the chassis (I've not seen any).
I've noticed two openings in the firewall, but I can't quite figure out what they are for. It looks like there might be a place to screw a cover over them, but I can't figure out what the cover would be called (if it exists), and I haven't been able to locate a picture of it in the assembly or maintenance manuals.
Can someone take a look at the attached pictures and tell me if I should be covering these holes up, and if so, what the part to cover it with is called?
Hole locations in the firewall.
Closeup of the passenger-side hole.
Old May 1, 2019 | 05:39 AM
flat tire's Avatar
no need to cover. just access ports for body to frame nut/bolt
check under the dash for openings, such as brake/clutch rod, speedometer cable, wiring etc
heater box/controls working properly?
Old May 2, 2019 | 08:43 AM
tom Bishop's Avatar
Sounds like heater control cable may have slipped. Does heat increase when turning on blower motor?
mwightman
Apr 29, 2019 02:18 AM
vipe155
Sep 13, 2018 04:05 PM
zaxroom
Feb 25, 2009 11:17 AM
Gorn
Jan 11, 2008 11:23 PM
Dice
Jul 13, 2007 03:20 PM
