Decode this tag please!
Old Aug 2, 2011 | 08:24 PM
djt511's Avatar
Default Decode this tag please!
How much info can a few pictures tell you?
File Type: jpg
Old Aug 2, 2011 | 08:27 PM
djt511's Avatar
Old Aug 2, 2011 | 08:43 PM
Unfortunately, the 68 trim tags aren't very informative. This is it:
Old Aug 2, 2011 | 09:10 PM
djt511's Avatar
Thank you, and where exactly do i look on the engine to decode it? Or can you tell what this engine is from just by looking at it?
Old Aug 2, 2011 | 09:38 PM
Easy, that's a small block Chevy!
From the looks of having no accessory holes on the front of the heads, your engine might be vintage to the car.
This site has some good info for checking if you have a numbers matching engine, etc.: Camaro Decoding help on Chevy-Camaro.com
Old Aug 2, 2011 | 09:48 PM
djt511's Avatar
So i have the partial vin and engine code.
101127147
T1023cgr
I just bought this car today, figured it wasn't numbers matching, but always exctiting to know the history when the PO didn't! thanks again for the help, gonna go back now and look for the casting code.
Old Aug 2, 2011 | 10:00 PM
You'll need to get the casting number off the block (drivers side bellhousing flange) to cross-reference some info. That cgr suffix code was used on the 1971 350, and 1970 400 engine. They would not be the same block casting though, way different.
Old Aug 2, 2011 | 10:48 PM
djt511's Avatar
i can't seem to see where these digits are, to the right below the dist cap?
Old Aug 2, 2011 | 10:52 PM
Click on the link I put above in post #5.
Old Jan 15, 2012 | 06:14 PM
Blew68's Avatar
did you get things figured out ?
mikes68
Aug 1, 2012 09:49 PM
oreocreaming
Mar 22, 2011 05:05 PM
acfitz
Oct 26, 2009 05:29 PM
mikemaccham
Apr 18, 2008 12:54 AM
1stgenssclone
Dec 2, 2007 01:30 PM
