Can I pull out the eng/trans out together '67
Old Feb 10, 2007 | 08:45 PM
dhenkel's Avatar
Default Can I pull out the eng/trans out together '67
I have a '67 camaro with a 350 4spd saginaw trans.Can I pull this como out together .I plan on taking the hood off and the fan blade.I want to leave the headers on.Do I pull the trans crossmember out and the shifter than pull it?Thanks
Old Feb 10, 2007 | 10:50 PM
MadMikeZ28's Avatar
Default RE: Can I pull out the eng/trans out together '67
You may be able to pull the motor far enough forward to clear the crossmember then you have to be able to tilt the motor and trans at a steep level to get it out as one unit.
Old Feb 10, 2007 | 10:57 PM
bowtieguy's Avatar
July 2009 ROTM
yes you can do it,but go ahead and pull the transmission crossmember you will need it out of the way when you put everything back in,just put a jack under the tranny untill you get the weight of the motor on the hoist.wouldnt be a bad idea to get the radiator out of the way.madmike is right ,you will have to put some angle in it to get it out.
Old Feb 14, 2007 | 01:22 AM
68berserk's Avatar
all the above are correct, crossmember out.....stock headers can stay on.........after market headers, take 'em off......it'll go back the same way.....have fun....Jeff
Old Feb 14, 2007 | 01:44 AM
68berserk's Avatar
sorry....new to the forum.....Jeff
Old Feb 15, 2007 | 04:24 PM
Blade's Avatar
June 2007 ROTM
I pulled the front clip off and pulled the motor and tranns as a whole. Yes u have to take the headers off before u can pull everything out!
OneHotMamma
Jan 18, 2015 08:24 PM
crooked421
Oct 5, 2010 10:22 AM
A-ron
Jul 15, 2009 05:44 PM
buckmaster
Jun 21, 2008 12:50 PM
JoeKramer
82-92 V6 Tech
Apr 18, 2008 02:32 AM
