Camaro starter issues
Hello,
Recently i have some issues with the starter of my camaro.
It's an '75 350 V8 engine.
I have opened my starter and the brushes are ok. When i put the - on my starter and put the + on the starter and connect the contact the starter tiks because the mechanical shifter is pushed forward but the starter doesn't turn ... So when i put - on the starter and connect the rotor straight to the + it turns !
so it goes perfect sep. but when it comes together it doesn't work !
can somebody help me pleas ?
thanks already...
thanks already...
As Pete suggests, common problem with a very well used solenoid.
You can take of the plastic cap, reverse the bolts and turn the disc to gain 'new' contact points between these items.
Or buy a new AC/Delco or Standard Motor Products solenoid.
