camaro info
Well, based on the vin alone I can tell you its a 1968 non convertably Camaro, built in Van Nuys, California. The numbers after the 'l' are sequencial numbers for the body... there is some level of debate weather GM started at 0 or 100,000. Either way yours start with a 3, this is midway through the prduction (as they ended near 6) so its probably not an SS or RS or Z28.
Where did you get the number for the 'vin'? Can you take a pic of the trim tag and post it? or describe, in great detail (it matters) what the trim tag says?
