Bumper replacement
Old May 29, 2010 | 04:59 PM
hawkster3's Avatar
Default Bumper replacement
Hi,
I want to replace my front and rear bumpers on my 1969 Camaro. Any advice on removing them would be greatly appreciated as I have never done anything like this before.
Old May 29, 2010 | 06:19 PM
I think once you lay on the ground and look up at the bumpers, it will start to make sense. The back bolts (4) are accessed from inside the trunk, look opposite the chrome bracket bolts on the bumper for reference.
The front ones can be removed from underneath the bumper, or you can remove the bumper bracket from the frame if you have to. The bumpers also have lower "horns" that attach to the body, so remove those bolts too. And an extra pair of hands will help to prevent scratching the paint.
Old May 29, 2010 | 11:08 PM
Squid's Avatar
well....we just put the rear one on ours.....
The bumper bolts as said above are inside the trunk. From left to right, there's a bolt in the far left corner, 2 bolts under the reverse light, a bolt to the left and to the right of the trunk release, 2 bolts under the reverse light, and then the one in the far right corner. The center 2 bolts go to the tag light bracket. Also, don't forget to disconnect the tag light before removing any bolts.
I'd recommend getting new bolts for it as well. Depending on how long they've been on there, you might have to cut the old nuts off to get the brackets free.
Haven't put the front one on yet, but it's simpler than the rear.
Old May 29, 2010 | 11:24 PM
Speed Freek's Avatar
A Tip:
Wrap some towels over the ends to avoid hitting the paint with the sharp edge so you wont scratch it if your doing it alone.
Old May 30, 2010 | 09:47 AM
hawkster3's Avatar
Thanks for you help. Let you know how it goes.
Old May 30, 2010 | 09:49 AM
hawkster3's Avatar
Nice detail. This is what I needed to know. Thanks. Let you know how it goes.
LeadHead
Oct 14, 2012 01:08 AM
tscw96
Jun 17, 2012 12:20 PM
Kingscolor
Oct 29, 2011 10:18 PM
BoricuaHec01
Oct 22, 2010 07:49 PM
VanHalen
Sep 1, 2009 11:46 AM
