brake line question
Old Aug 6, 2012 | 10:56 AM
jumpcannon's Avatar
Default brake line question
I removed the power booster/master cylinder and replaced it with a MANUAL Wilwood master cylinder. I am running new brake lines through the whole car and ordered pre-bent lines for manual setup....unfortunately they were bent like the previous ones i took out which make them come all the way up over the master cylinder. So i sent them back a reordered from a different company. On a manual setup do i use the original distribution block bracket? Anybody ever make this change before? Brake lines are a pain in the A$$....so trying to do my homework first.
Old Aug 6, 2012 | 12:56 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
is the car front disc/rear drums or all drum?
Old Aug 6, 2012 | 08:38 PM
jumpcannon's Avatar
the car was power drum/drum.....i have now converted to disk/disk. they are not giant oversized calipers....they are 4 piston calipers from wilwood. and also a wilwood master cylinder that i already mounted to the firewall and mounted the push rod to the "manual" hole on my brake pedal for more force. master cylinder is 7/8th bore for more pressure. i wanna start plumbing in my line lock....but not messing with anything till i get the brake lines in and distrubition block mounted in the correct postion.
Old Aug 11, 2012 | 03:59 PM
Smee78's Avatar
I would call Wilwood and see what they say, I bet they have had this question a few times and would have the anwser. Let us know what you find out.
Old Aug 12, 2012 | 03:36 PM
jumpcannon's Avatar
ok....i ordered manual stainless steel brake lines from a different place (heartbeat) and they sent the correct ones! they bolted right into the distribution block and i used the original distribution block bracket. MMMMM....they look nice!
Dcapper81
Apr 22, 2012 11:21 PM
timmyz28
Mar 30, 2011 09:01 PM
65eglide
LS Series Tech
Mar 25, 2011 09:23 PM
traumadog
Aug 2, 2009 01:27 AM
trotro
Dec 20, 2006 02:52 PM
