Best rear gear ratio???
Old Jul 31, 2019 | 05:27 PM
  #21
Originally Posted by Aussie Rog
'69 Camaro 396 manual 4 speed, 225/60/15 tires and I want a diff ration for highway cruising? It's a 12 bolter diff that's on the car. Can anyone give suggestions and American suppliers.
You want taller gear for the highway I see,I ran 3:90's in my big block '69 with a 4 speed and was pretty happy with them,not too low like 4:10's but still plenty of jump off the line.
What gears do you have now?
3:73's or 3:55's might be better if you do a lot of highway driving.
What 4 speed do you have,that makes a difference as well.,wide ratio might be better for highway driving and close for city,where do you spend most of you driving time?
Old Jul 31, 2019 | 10:07 PM
  #22
Zspoiler's Avatar
You can run a 3:55 to 3:73 with a 12 bolt .and or 3:42 gears with a 8.5 10 bolt With a 26-8 tall tire.
Old Aug 4, 2019 | 01:20 PM
  #23
SoCal67's Avatar
either 4 speed has the same 4th gear ratio of 1:1 so no difference in final gear RPM's between the two at any speed
if fwy driving is a strong use than go with a higher gear. Use one of the online RPM calculators you enter your tire size and tranny type and select a given gear ratio available for your rear end and it will tell you what RPM at what speed you will have. Make a determination based on that info
Old Aug 4, 2019 | 09:15 PM
  #24
Then what is the point of having a wide ratio trans?
Old Aug 4, 2019 | 09:50 PM
  #25
Zspoiler's Avatar
The RPM the engine best work at .And what you want the car to do. Like a road course likes a close ratio gear box.Because there is limited RPM drop .And wide ratio box works good for pulling heavy loads .
Old Aug 4, 2019 | 10:19 PM
  #26
If you're using highway gears (3.55 or higher), I think you might be happier with an M20 wide ratio trans. It has considerably lower 1-2-3 gears compared to the M21 close ratio model, which will give you better off the line performance.
Old Aug 5, 2019 | 10:29 AM
  #27
SoCal67's Avatar
the term "close ratio" and wide ratio" mean on a close ratio the gear ratio (numerically) is closer together from gear to gear vs a "wider" ratio from gear to gear.
For drag racing and quicker acceleration shifting through the gears you want a close ratio
Most want a close ration trans
Old Aug 5, 2019 | 12:10 PM
  #28
Everett#2390's Avatar
2.20 would need a 4.56:1 rear gear; 2.52 would be a 3.90:1 ratio.
Old Aug 5, 2019 | 01:45 PM
  #29
SoCal67's Avatar
OP
use this, or any other one online, to determine what RPM your motor will run in 4th with whatever tire size you have or will get and decide what rear end gear ratio provides the RPM's in 4th (1:1) that is acceptable to you
I had 3:73's which was great for stop light to stop light but got old if wanting to sustain 65, or higher, mph for a hour or so on the FWY so I went to 3:08
Overdrive transmissions are certainly the win win. I have 4:10's in my T56 car and am under 2k RPM at 80 mph in 6th with a 27" tire.
Do the math and make a choice on what RPM at FWY speeds is acceptable to you
calculator
https://spicerparts.com/calculators/...rpm-calculator
Old Aug 5, 2019 | 05:09 PM
  #30
My thoughts exactly for a highway geared car.
the term "close ratio" and wide ratio" mean on a close ratio the gear ratio (numerically) is closer together from gear to gear vs a "wider" ratio from gear to gear.For drag racing and quicker acceleration shifting through the gears you want a close ratio
Right I understand that but he asked about highway gears not drag gears so wide ratio was my thought with tall rear end gears.
the weiand one
Oct 7, 2013 12:51 AM
LetsRocZ28
16
Jan 10, 2011 07:23 PM
chewybacca11
Dec 16, 2009 02:13 AM
bowtie70350
LS Series Tech
11
Apr 21, 2007 12:01 AM
ScottD
Nov 11, 2006 10:35 PM
