LS Series Tech 1998-2002
Rear end Gear
Old Mar 10, 2007 | 01:39 PM
bowtie70350's Avatar
Default Rear end Gear
Hey all. I have to replace the ring and pinion in my 2000 SS and am looking for some advice. The stock ratio is 3.42(it has a 6-speed). I was thinking of changing to a 3.73, 3.90, or 4.10. I know what you're thinking, 3.90 isn't really a GM gear but I hae found some gear manufacturers that offer this ratio. Anyone had any experience with these three ratios in their ride? Which is preferred? Any particular manufacturer/retailer I should get these from? The car is not a daily driver but it's not a track car either. I just want the gear that will give the car the most "fun" factor with out sacrificing driveability. Thanks
Old Mar 10, 2007 | 06:30 PM
Lee Willis's Avatar
Default RE: Rear end Gear
We put a 3.73 in our Camaro. It helps a lot since we upped the rev range and lost a good deal of low eng torque by using a really big cam.
The 3.90 ratio is a pretty good gear for some situations, particularly since the 4.10 gets to be pretty extreme for some folks. We thought of using it but we got a good deal of a really strong 3.73 so we went with that.
On the other hand I'm going to the other way with the vette, to a 3.15 from a 3.42.
There is a very long post on the pros and cons of changing rear end ratios on this forum's sister Corvette forum -- there are donwsides beyond just the higher revs on the highway, etc, but you might find it interesting.
http://www.corvetteforums.com/m_26639/tm.htm
Old Mar 10, 2007 | 09:57 PM
JD1969's Avatar
With a 6 speed there is no reason not go 4:10, both 5th and 6th are overdrive gears, so it won't suffer much, if at all, on the highway. The only down side is that, if your still on a stock 10 bolt rear, the bigger gear will reduce strength in an already weak rear end.
Old Mar 11, 2007 | 12:37 AM
o2camaross's Avatar
Hey Lee, your post on corvetteforums was extremely informative and well done. You covered the M6 in that post and I am pretty sure that, thats what I have but im not completely sure. I have an 02 SS, do I have an MN6 or a T56?
Old Mar 11, 2007 | 12:38 PM
JD1969's Avatar
You have a T-56
Old Mar 11, 2007 | 07:38 PM
Lee Willis's Avatar
ORIGINAL: JD1969
If you go with any improvement in power youwill eventually have to face replacing the rear axle with something stronger, so count on that now . . . you can do what my son and I did - replace it three times -- but eventually you get tired of that and go with something stronger than stock.
Old Mar 11, 2007 | 07:53 PM
JD1969's Avatar
That's 100% true Lee, I just want him to know that the rear is WAY more likley to break with that 4:10 in it and he should be ready to invest $2000 in a 9 inch or 12 bolt.
Old Mar 16, 2007 | 03:14 AM
91c4guy's Avatar
don't go 4.10, you will get tired of it, 3.73 safe bet.
Old Mar 16, 2007 | 10:44 AM
JD1969's Avatar
ORIGINAL: 91c4guy
Have youever drivin a 6 speed car with a 4:10?
Old Mar 16, 2007 | 02:37 PM
SSsuperdave's Avatar
4.10s Are the way to go. I'm sure my 10 bolt will break someday, and when is does I'll worry about it then, untill then I enjoy every minute of it.!
