67 camaro straight 6 to small block swap. What do I need to To know
Old Aug 5, 2019 | 08:13 PM
Corndawgdorkfish's Avatar
Default New 1st gen owner67 camaro straight 6 to small block swap. What do I need to To know
Old Aug 5, 2019 | 10:42 PM
Pretty straight forward deal,motor mounts (both frame and engine),bigger radiator with a fan shroud and V-8 fan,new exhaust of course.
You'll need brackets for your accessories, PS pump & alternator is all it looks like there,my '69 didn't even have power steering.
If you were to go big block you'd need a big block heater core.
Old Aug 6, 2019 | 06:29 AM
Thank you for the info ! I’m also putting in a t5 5 speed hydraulic. I think I have a great platform to work with. This car is all original except for the wheels. I paid 4500.00 for this car and it is in great shape overall. I have no idea what this car might be worth so I am keeping everything I take off the car I always wanted one and finally this one landed in my lap lol any does and donts will be appreciated I will post pics of the progress
Old Aug 6, 2019 | 09:49 AM
You might want to do some reading here: https://www.jalopyjournal.com/forum/...-chevy.232700/
if you plan on using a T-5.
If you plan on making much power at all I'd stick with an old school 4 speed Muncie or BW T-10 myself. Or if possible get all the parts for a T-56 six speed conversion.
https://www.hotrod.com/articles/ever...ur-gm-project/
A good running mild built 350 can destroy a T-5.
Old Aug 6, 2019 | 10:27 AM
flat tire's Avatar
I agree with Y2Keglide. stick with a Muncie and then add a gear vender over drive unit to it . I love mine.
with a 3:55 rear gear I can run 80 mph and turn 2600 in 4th OD
Old Aug 6, 2019 | 12:58 PM
SoCal67's Avatar
OP
+3 on the T5 being a fragile trans behind a V8 bigger than a 305 2 brl motor. You can put around with it but driving it....well like you likely want to behind a 350 ci V8 and it will be short lived
Consider a Muncie 4 speed or a TKO 5 speed if you want a OD trans
Old Aug 6, 2019 | 01:27 PM
Thanks for the info y’all!! I will keep y’all posted on the process !
hdrocks
Mar 17, 2012 08:27 PM
steve6754
Mar 1, 2012 02:20 PM
scatterbrained
Mar 30, 2010 09:16 AM
scatterbrained
Feb 1, 2010 09:57 PM
gozzy341
Mar 31, 2008 03:23 PM
