700r4 transmission problems
Old Jan 21, 2018 | 08:54 PM
Ernie Crispin's Avatar
Default 700r4 transmission problems
i just installed a 700r4 transmission in my 67 camaro. having trouble with car stalling out whenever i place the car into drive or reverse?? torque converter is a 2800-3000 stall converter and my engine is a 383?? any thoughts off hand?
Old Jan 22, 2018 | 03:13 PM
Assuming your foot is on the brake, from the transmissions point of view the only difference from forward to reverse is the front pump needs to work a little harder to create more line pressure in the trans. There is more stress in the transmission once you start moving but not before.
Maybe your tune is right on the edge of stalling and the extra 1-2 hp needed to run the higher transmission line pressure is enough to make it stall? The torque converter itself is working exactly the same forward or reverse. It sounds more like a carb/timing adjustment and less like a transmission issue.
Old Jan 24, 2018 | 06:07 PM
Everett#2390's Avatar
Agree with Gorn, fix the engine tune.
BTW, the high stall convertor will act like a stock one under light throttle/normal driving.
It will just slip more than a stock t/conv at heavier throttle/load.
Expect about a 200 RPM drop between neutral and gear.
Old Jan 27, 2018 | 06:01 PM
Jus Cruisin's Avatar
What rpm is the car idling at in park/neutral?
Old Jan 29, 2018 | 06:45 AM
With a stock Cam between 650-800 RPMs. With an aftermarket Cam whatever works, I had a race car that would not idle under 1800 RPMs. Its pretty common for a 1000 RPMs on a lower aftermarket Cam.
Old Jan 29, 2018 | 06:50 AM
^^^ I was asking the OP what his idle was.
He was apparently a drive-by....... One post and gone.
itrustno1
Dec 3, 2015 04:22 PM
knightrider1632148
Mar 19, 2009 11:21 AM
Blue79ice
Jan 25, 2008 04:17 PM
73 T Top
Apr 22, 2007 01:07 AM
Booder
Sep 5, 2006 08:50 PM
