69 camaro power steering box
Old Jun 9, 2010 | 10:07 PM
jjc1800's Avatar
Default 69 camaro power steering box
having a problem getting my header on because of the steering box being in the way. i was wondering does anyone know of a smaller power steering box than the stock one that i can put on? i believe the one thats on there is a 800 series box.
Old Jun 10, 2010 | 07:38 AM
Squid's Avatar
unbolt the steering box, install header, rebolt steering box. If you got the headers that fit the 69, then they'll fit.
Old Jun 10, 2010 | 12:59 PM
shevrolay's Avatar
Do what the rest of us, mark the area where the header contacts the steering box. Heat that area up, lay a bar across it (Floor Jack Handle) and give it couple good whacks with hammer. You'll want at least 1/4" to 3/8" of clearance.....and don't worry it won't hurt your Headers performance. Good Luck
Old Jun 10, 2010 | 09:45 PM
carguy68ssrs's Avatar
Are 69's frame that different from 68? I have a bb and 2-1/8 primaries and no problem with fit, Hooker Headers if your wondering, and power steering
Old Jun 10, 2010 | 11:13 PM
Squid's Avatar
it's not a case of the headers fitting once in place...it's a problem of getting the headers to get into position around the steering box.....it's a case of having the headers bolted on when dropping the motor down or lift the motor up/pull the ps box to get the header to get into position.
locke1990
Sep 29, 2012 04:56 PM
Kerri Murphy
Apr 6, 2012 02:03 PM
301Breed
Feb 21, 2011 11:00 AM
lynchingacers
Apr 24, 2010 08:57 PM
QUICKB4C
Jun 29, 2009 09:34 AM
