'69 alternator belt
'69 alternator belt
Can anyone recommend a good way to tighten the alternator belt?. I'm not having much success.('69 with a/c) Putting on a new belt and can't really find a good way to pull the alternator tight enough. Just pulling the alternator by hand isn't doing the trick.
Thanks....
Thanks....
There is a tool you can buy that is real cheap. It goes between the alternator pulley and crank pulley. You then use an open end wrench to expand the tool and it pushes the two pulleys away from each other. You then tighten the upper and lower alternator bolts. . . . The other way is like Smee78 said, use a pry bar. If you go this route, tighten the bottom bolt first, then the top one.
IronCactuar
07-19-2013 01:47 AM
