68 camaro windshield w/antenna
Old Feb 14, 2011 | 07:41 AM
StoveBolts's Avatar
Originally Posted by dynarider33
Any auto glass company can get you one with an antenna.
I just went through this just over a month ago without any luck. Actually, our local Glass company searched high and low without any results, so I called other glass companies in the area and still, nobody could find a windshield with an antenna built in. I even spent a couple day's browsing the internet and still, nothing.
Seems to me that there may just be a market for this...
Like another poster said, "Aint no way I'm drilling a hole".... I'm just going to mount mine in the trunk for now and not worry about it. Who listens to the radio anymore anyway?
Old Feb 14, 2011 | 07:55 AM
BasicConcepts's Avatar
Technical User
^ I've used one of those before years ago. JC Whitney here in Chicago used to sell it, not sure if they still do. Problem was, the aftermarket type, as well as the old factory built in one, didn't give nearly as good of reception as mast antennas do.
ive used that exact one it worked great for me
Old Feb 14, 2011 | 08:00 AM
I'm gonna have to start making sure I quote people, because your original response that I responded to was about a tape on wire type. That style that you changed the link to didn't exist in the 70's. Good to know that one works well. Does it use the car's electrical system as an antenna, or is there still some wire attached to the windshield?
Old Feb 14, 2011 | 08:03 AM
Technical User
no but it does need to be hooked up to 12 volts
Old Feb 14, 2011 | 08:08 AM
No to which one, I had two questions!
Is the box itself the antenna then? That makes three questions now!!!
Old Feb 14, 2011 | 08:15 AM
Technical User
the only electrical is the 12 volts and you just run that to the power antenna in the radio and the actual antenna wire also just run that to the radio
and yes the box is the antenna
Old Feb 14, 2011 | 08:24 AM
OK, cool. And you'd say reception is every bit as good as with the mast antenna? I don't like external antennas.
Buckskin
67-69 V8 Tech
Oct 29, 2011 08:12 PM
henrysangret
Oct 23, 2009 12:54 AM
bobyo
Jun 20, 2009 08:43 PM
1995Camaro
Mar 9, 2009 07:47 PM
cautioncones
Dec 27, 2008 06:06 PM
