68 Camaro makes a clacking sound when it starts up ???
Old Jun 23, 2010 | 10:17 PM
50 cool 50's Avatar
Default 68 Camaro makes a clacking sound when it starts up ???
hi guys
when i turn the key of the camaro she makes a strange noise as shes starting up.
sounds like something is catching or cracking inside the starter motor. like maybe teeth catching and grinding sort of a noise just as the starter engages
as soon as i let go of the key shes idles just fine. nice and quiet. its only when i turn the key
any ideas?
thanks guys for all the advice
Old Jun 24, 2010 | 01:39 PM
shevrolay's Avatar
I'll take a wild guess.....Starter Solenoid. If you don't mind a little arching there is a way to check:
http://www.type2.com/bartnik/starter.htm
Old Jun 24, 2010 | 01:49 PM
50 cool 50's Avatar
could it be a case of the flywheel not engaging properly and thats why its making the clacking noise?
Old Jun 24, 2010 | 03:13 PM
That's what it "sounds" like to me. Although I can't hear it, so it's just a best guess based on the description.
If you were able to post a sound byte, it would probably help.
WIspartan1026
Oct 12, 2012 01:38 PM
swalsh
67-69 V8 Tech
Feb 22, 2012 09:34 AM
fuhhuayt
Jun 5, 2011 02:03 PM
Cammy 3.8lV6
Nov 12, 2009 11:09 AM
CIN
Apr 17, 2008 05:20 PM
