68 Camaro makes a clacking sound when it starts up ???
hi guys
when i turn the key of the camaro she makes a strange noise as shes starting up. sounds like something is catching or cracking inside the starter motor. like maybe teeth catching and grinding sort of a noise just as the starter engages as soon as i let go of the key shes idles just fine. nice and quiet. its only when i turn the key any ideas? thanks guys for all the advice:icon_couchhide: |
I'll take a wild guess.....Starter Solenoid. If you don't mind a little arching there is a way to check:
http://www.type2.com/bartnik/starter.htm |
could it be a case of the flywheel not engaging properly and thats why its making the clacking noise?
Originally Posted by 50 cool 50
(Post 434297)
If you were able to post a sound byte, it would probably help. |
