396 Quadrajet ??? which one was right?
RE: 396 Quadrajet ??? which one was right?
Original: 69Camaro1
I came up with 7029200 for automatic and 7029201 for a manual. Go to http://www.chevy-camaro.com/parts/chevy-camaro-part-codes-carb.htmfor morepartnumberson holley and rochester carbs on first generation camaros'.
rare is good right? the numbers on the trans match the numbers on the protect o plate so...... l also have the hand written and typed invoices. The guy l bought the car from, his dad bought the car new for 3622.50 out the door. listed equip was S.S. EQUIP, 325 HP ENGINE, DOOR EDGE GRDS,FLOOR MATS, TURBOHYDROMATIC,POSITRACTION,AUX LIGHTING, RADIO,VINYL ROOF,RALLY COVER, CONSOLE,POWER STEERING,F41 SUSPENSION, SP. INSTRUMENTATION & UNDERCOAT
ORIGINAL: Ejam
Quadrajet
Don't know if you found the answer you were looking for. If not try,
www.holistic.com/camaro/parts/carbs.htm
This will give you a breakdown of all the '69 Camaro Carburators. Some came with Holleys, some Rochesters and some made by Carter for Rochester. The ones built by Carter have Made by Carter stamped on the carb. You were correct with the number you had 7029200, it is the correct series, the last two numbers should be, 01,02,03,04,05 and so on.
Best of luck. I'm jealous.........
quadrajet
Here's another place to check
chevyinfo.net/htm_%20pages/carbcode.htm
Don't know why this web page did not turn blue.
I've got a '66 Impala 396 and it is the same carb #
Just above where it says Quadrajet it should say Rochester, the Carter built carbs used the same part numbers. Chevy, or GM for that matter, really weren't choosy what they put where. You might find a number carb designated for a truck sitting on the origional engine in a car. Also GM did not keep any records on the cars they built, except Corvette.
Hope this helps
Hope this helps
You sounded like you are kinda new to this so I've probably given you carburetor overload. But I learned by searching the Internet and reading without much help from anyone so I like to help when I can.
This should help:
Camaro Carburetor Identificatio9n.
Example: # 7028219 DG and 1938
70= prefix code "70" will appear on all late 60's Rochester Carbs.
2= Decade production
2=1960's
3=1960's A.I.R.
4=1970-1975
5=1976-1979
6=1980's
8= year produced 1968
model
O-monojet (1bbl) Fed Standards
1-Two jet (2 bbl) " "
2-Quadrajet (4bbl) " "
3-Monojet (1bbl) Califonia Standards
4. Two Jet(2bbl) " "
5. Quadrajet (4bbl) " "
1 General Motors Division 0,1,2 indicate Chevrolet
9 Transmission even numbers = Auto
odd numbers = Manual
DG = Customer Code
1938 = Date Code; located on various locations on different Carbs, This # indicates the mfg. of the the carb. The first three digits correspond to the day of the year and the last number indicates the year of production
example: 1938 = 193rd day of production of 1968
Clear as mud right? Will not bother you any more. but this should give you a heads up on the quadrajet....Don't believe everythig you hear about them.....they are great carbs and will give you great serevice, like anything man made, they have their faults. I and a lot of friends run quads and love them. There never was and never will be the sound produced when you hit the throttle and those two back afterburners kick in .......enjoy my friend
This should help:
2=1960's
3=1960's A.I.R.
4=1970-1975
5=1976-1979
6=1980's
model
DG = Customer Code
I don't know about rare, I have a 68 SS/RS 396 with th400,air,pw,pdb,deluxe interior, black hounds tooth,fold down back seat, vigilights, tilt column, remote driver mirror, deluxe chrome on outside,big ugly bumper guards
