396 Crank and 454 Block?
A shop advised they can build a 427 by using a 396 crank and a 454 block. A friend stated that the 396 crank is not properly balanced for this setup and advised to use a 427 crank vs. trying to balance a 396 crank. thoughts?
Your friend is wrong,a 454 crank is balanced externally because of the longer stroke and uses a different flywheel and harmonic balancer than all the other smaller big blocks,396,402,427.
Both the 396 and 427 are the same stroke, the 427 is just a bigger bore,they are balanced internally and use the same flywheel and balancer.
So yes you can use either a 396 or 427 crank in a 454 block to make a 427 and use the flywheel and balancer for a 396/427.
Interesting. When I do a Google search on "396 crank with 454 block", I get more than one person stating that threre is a difference and many advise there is no difference. Intuitively, you would think there would be a slight difference in balancing to offset the added weight of 427 pistons (bigger means heavier). Maybe today's pistons are lighter than they were 40 years ago?
