327 Inline Fuel Filter Empty
Old Jan 22, 2019 | 07:50 AM
bsnowrider's Avatar
Default 327 Inline Fuel Filter Empty
I have a clear filter between my fuel pump and my carb. After sitting for 4 or 5 days, there is no fuel in it. If I crank the engine, it eventually fires up and runs fine. Warm starts are also fine. Is the fuel draining back down towards the fuel pump? is this normal?
Old Jan 22, 2019 | 07:00 PM
Everett#2390's Avatar
More than likely, fuel is evaporating due to today's recipe.
Old Jan 22, 2019 | 09:53 PM
Zspoiler's Avatar
There should be some fuel in the float bowls. You might have to pump the gas pedal a few times before you start it.
Old Jan 26, 2019 | 09:26 AM
On a side note, is that filter plastic or glass? If a plastic one, you might want to seriously consider replacing it, as they can be a potential fire hazard. They work great for lawn mowers though.
chuckles
Nov 9, 2012 05:04 PM
jon_uscg2001
Aug 25, 2011 12:23 AM
Jr. Mechanic
Aug 15, 2008 09:34 PM
bigdood717
Jul 30, 2007 03:18 PM
bowtieguy
Dec 17, 2006 12:16 PM
