1969 Camaro Tach with HEI Distributor
Old Dec 30, 2009 | 09:07 AM
Moe Watts's Avatar
Default 1969 Camaro Tach with HEI Distributor
Hi Guys. I am thinking about adding a GM or MSD HEI distributor and upgrade my dash by adding an in-dash tachometer and center fuel gauge.
1) Will the in-dash tachometer work ok if connected to the "tach" lead on the HEI distributor? Any special wiring harnesses required?
2) Is the HEI type the right way to go or should I stick with a standard external coil setup? I'm looking for reliability but want a hotter spark.
3) Anything else I need to be aware of?
Thanks for your help.
Old Dec 30, 2009 | 11:46 AM
1) The tach hookup on an HEI works the same as on an old external coil setup.
2) If you're comparing HEI to points ignition then HEI is the way to go. You will notice a difference in performance, and the engine will start up with a tap of the key.
3) Mark all your wires and the rotor position before removing the old distributor, and reverse the order to install the new one.
tnomi
Feb 24, 2015 08:20 PM
socalrs
Jan 20, 2012 11:05 AM
TearsInTheRain
Jun 15, 2007 10:02 PM
D~C
Jul 16, 2006 01:41 PM
