1969 Camaro ss 396 highway headlights
Old May 30, 2019 | 12:14 PM
Gator24's Avatar
Default 1969 Camaro ss 396 highway headlights
What are the correct wheels for this car. Factory wheels. 2nd question 1969 Camaro DZ 302 muncie transmission. Need new clutch factory original needs replacing. Light street and some track type takeoffs. Any suggestions thanks to all
Old May 30, 2019 | 10:06 PM
Pretty sure the '69 Z28's had the 15" rally wheels and as for the clutch if the rest is stock an OEM stock clutch should be fine,you can spend a lot more if you want of course but that would probably be overkill.
https://www.automobile-catalog.com/t...ort_coupe.html
Old May 31, 2019 | 08:49 AM
I like the center force dual friction clutch. Sitting in the car if feels stock but has 80-90% more holding power and will out last a stock clutch treated the same way. It is by no means a race clutch just upgraded stock clutch.
Old Jun 1, 2019 | 07:51 AM
Depends on when your car was built. These are the SS wheels up to a January build date, then they were discontinued.
Old Jun 2, 2019 | 10:46 AM
Bet those are rare as hens's teeth these days,only came on the SS right? I think the Z28's only came with the rally wheels.
Old Jun 3, 2019 | 12:22 AM
Only 314 of them to be exact, so yeah pretty rare.
tespjs12
Dec 17, 2012 02:11 PM
SMatyac
Jun 16, 2012 02:02 PM
dogdog130
Apr 21, 2011 11:37 AM
Chaotic94
Sep 27, 2010 09:23 PM
armyvalues01
Jul 10, 2008 04:54 PM
